Hi all,
can you please check my Shopping-List for my first mini Build.
I cant spend too much
and it should be silent as possible (Livingroom PC)
Im not planning to do OC.
Dose the setup make sense?What would you change?
Will this all fit in the case?
Is ist possible to build it cheaper without loosing significant performance?
Thank you!!
geizhals.de
Thank you!!
Mini ITX Build Preisvergleich Geizhals Deutschland
Preisvergleich und Bewertungen für Mini ITX Build
