• SFF.N will be offline briefly for planned maintenance on May 24th, from 11:00 PM to 11:30 PM EDT.
FanlessPC Custom Build
watts_happening
Hi folks, it's been a while since I did a custom build. The last one was about 2015, putting a NUC-style Gigabyte Brix Pro 4700R into an Akasa Euler case left over from a previous build. It's time for an update, which will be used for general purpose computing with some light gaming (flight simulators). As it will be going in my home office, I'm optimizing for silence as well as something that doesn't heat up the room at idle but can burst to higher performance for the occasional heavy workload.
Total power budget is 65W for the CPU + 75W for the GPU, run from an external 192W AC-DC power adapter.
I recently came across some nice custom cases made by FanlessGuy, who has a youtube channel showcasing his work. What appeals to me is the stylish efficiency of building a "case" around a big giant heatsink. Unfortunately, I don't have a lot of free time, so this will be a slow process (about 2 months and counting so far), but I will post updates when I can.
Parts List
  • Microstep TH310C-P motherboard - this is a nice ITX board with a side-mounted PCIe slot, only available direct from China as far as I can tell
  • MSI GEFORCE GTX 1850 D6 AERO ITX OC - new GDDR6 version of the 1650 with a 75W TDP (no external power required)
  • i7-9700F CPU
  • Samsung (MZ-V7S1T0B/AM) 970 EVO Plus SSD 1TB
  • HyperX Impact 32GB 2666MHz DDR4 CL16 SODIMM Laptop Memory HX426S16IB/32
  • 12V 192W AC-DC power supply from mini-box.com (makers of the Pico PSU)
Case Parts
Motherboard with side-mount PCIe and MSI 1650 GDDR6 GPU:
Preview of the materials I plan to use. Bamboo ply is leftover cutoff from a counter install.
First set of blocks in 1-1/4 and 1 inch aluminum to allow extra space for other devices - have since decided to go to 3/4 and 1/2 inch instead to make the total assembly thinner
Test fit of heatsink blocks - will need a thin shim under the CPU block to even things out:
ignsvn
Member of the Order of the SFF.N Empire
Moderator
Apr 4, 2016
994
808
Nice, I didn't know that the vendors have equipped 1650 (non-Ti & non-super) with GDDR6 as well!
Arboreal
452
478
For 90 degree L shaped PCI mount for side mounting, which part did you use?
There is no adaptor or mount used here.
As per the OP, @watts_happening has bought a super specialised PIO thin ITX board available only in China.
It has a 16x PCIe slot on the 'wrong'side of the board and is mounted with the output parallel to the board, so 90 degrees away from teh usual design.
Very nice work, there; that is one serious heatsink you have lined up for the build!
Reactions: A415Hz
