I just completed an itx build & created a custom fan curve in the bios, before I start installing other software I want to make sure all temps are good. I also want to install iCUE so I don't have to go into bios whenever I want to make a change in my fans, here in lies my question:
If I already have a custom fan curve set in my bios, then install iCUE, (or any other software that allows me to control fan speeds, maybe Armoury Create), how does that play out since I already set a custom fan curve in my bios? Will there be a protocol issue? Does iCUE or any other software override the bios fan speed previously set? Do I need to set the bios fan speed curve to no fans spinning? My board is an ASUS z690i. Leaning more to iCUE, more familiar with software, tried Armoury Create awhile back & had to use uninstallation software to remove it, not a good experience.
Thanks for reading...jp
