In the year 2020?! Well, thanks for confirming. I've got another question regarding GPU thickness. I have an Asus RTX 2060 5.8 cm thick GPU. Will it fit? It only takes up 2 slots, but the cooler takes up 3.
I've only got a 2080 FE so I can't make guarantees on anything fitting tbh but I can at least give you an idea.
It appears that it could maybe fit but you would probably have to unscrew the handle with the two screws (the piece of metal next to the pcie slot openings) for it to actually work.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
