In general, what would you say about the durability of an ITX mobo when compared to an ATX mobo of similar grade. I am not talking about an entry level ITX compared with a top-of-the-line ATX mobo or vice versa. Also, I am not talking about the building skill of an individual but rather the overall average of all builders. Specifically, I mean, how is the design of an ITX mobo itself as well as its sitting inside a smaller case affects its lifespan when compared to that of an ATX mobo.
This is one of the issues that I have not found much discussion here or elsewhere (ie the durability of an ITX motherboard compared to an ATX mobo). I have read people complaining about the relative shorter life span of ITX mobos compared to ATX mobos. Explanations cited often are:-
a) the market of ITX motherboards is much smaller than that of ATX motherboards. So, manufacturers channel much less manpower and money into the board design. Thus, with an relative inferior design, life is shorter.
b) as an extension of above, components used are of lesser quality and this contributes to the worse durability
c) as an ITX board is smaller in size, heat generating components are more squeezed closely to each other than on an ATX mobo. This congestion affects the durability negatively.
d) an ITX mobo is usually inside a much smaller case in which other system components are up to each other's nose. The heat dissipation is usually not handled as well as an ATX motherboard sitting inside a larger case. Particularly, case airflow over an ITX mobo (to cool various components, eg VRM, chipset, SB/NB in the older days...etc) is usually nil or minimum, thus affecting mobo components adversely.
I have also read a complete opposite view, claiming ITX mobos have relative better durability because manufacturers use better components to build their ITX mobos because they are aware of the potential worse thermal condition inside a smaller SFF case.
What do you guys think? Longer lifespan, shorter or just about the same when an ITX is compared to an ATX mobo?
I have never used an ITX mobo before and so I am a newbie. Share your view and your first hand experience please.
