I changed it for you, I hope it's what you meant. I like that Dr Zaber went the extra mile in packaging. It's impressive to see this in a SFF case project like this.
Are those are custom feet in the second to last picture?
i hope James won't kick me for that![]()
I wish more places were like that.No worries. When SFN was started, it was made very clear that this would be allowed. Linking to builds on other forums provides valuable information, it would be bad for the user to forbid posting such links.
On SFF Forum you can absolutely link to other forums.
As a vendor you can also link to the crowdfunding page, company website, store page, etc. as long as you don't just spam it everywhere.
Yes. Those are custom feet. Ej24 switched them with the ones we are sending in a box with Sentry. Here is a link to original Ej24's post (i think Ej didn't post it here, so the link is from [H]ard forum... i hope James won't kick me for that)
- some of packages from 2nd transport were randomly checked/oppened by customs services in search for... ancient stuff robbed by ISIS in conflict in Siria... yeeey...![]()
So should I sell my CPU for a 65w version or is it ok as is?
Don't sell it, being a K suffix CPU you can always reduce the clock speed & voltage to reduce the heat output, sometimes you can even set the TDP limit itself. Swapping it for another i5-6000 won't bring any benefit.
Whether it'll be fine as is depends on what frequency you're currently running it at, what CPU cooler you're using and what level of noise you want from the PC. I'd try it in the Sentry first and then you can fiddle with the fan. frequency and voltage settings to get the desired noise level.
Another thing I was wondering, you recommend on your website that the CPU should be a max TDP of 65w, and GPU of 150w. I currently have an i5-6600k at 91w.
The system si currently in a Node 202 though and seems to be running fine afaik (I'm no hardware expert).
Thanks
LC
I think you should wait until you will get your case. Our recommended TDP of 65 Watts for cpu and 150W for GPU was set as an optimal balance between hardware performance, cooling performance and noise made by fans. It should be enought for 4K gaming and other casual heavy loads. If you go higher with TDP you can get higher temps, higher noise level or even throttling (with poor cooling). We have reports that many people went higher from our recommended values and they don't have throttling at all. Only a bit higher temps than in other SFF cases. You have to remember Sentry has something like 6.9 litres of internal volume. This is really small space, and you have to have good cooler for both GPU and CPU to keep those components on satisfactory level of temperatures.
