I am contemplating building an extremely compact DIY Case for a Micro Workstation that will fit in my briefcase.
It is efectively a Notebook substitute, with as much power as I can pack into as small a space as possible. I have had Notebooks for over 30 years, and never used them without plugging them in. I normally use my Notebook at home or in the Office with a monitor and keyboard plugged in. So why buy a replacement Notebook and pay for a Screen and Keyboard that I will never, well hardly ever use. My requirements when I'm 'Out-and-About', are more than adequately provided for, by my Samsung Tablet whilst I'm on the move, which I can then to RDP into the Workstation on arrival. Effectively my Tablet is then a wireless Monitor/Keyboard.
I am, unashamedly waiting for new technology to be released. I propose using:
- APU - AMD 8050 'Strix Halo', so I won't need a GPU, due early 2025, I believe.
- Motherboard - AM5 PCIe 5 mITX 870, to be selected when they are released.
- Air Cooler - Thermalright AXP90-X53 Full Copper low-profile air cooler.
- Thermal Sheet - Thermal Grizzly KryoSheet Thermal Pad, 33x33mm.
- Memory - 32 GB TEAMGROUP T-Create Expert DDR5 RAM - 6400MHz CL32.
- SSD - 1TB Corsair MP700 PRO with Air Cooler PCIe Gen5 x4 NVMe 2.0 M.2 SSD
- Case Fans - 2 x Noctua 80mm NF-R8 Redux Edition 1800RPM PWM
- PSU - HDPLEX 250W GaN ATX PSU
- 3.5" Front display for CPU info
- 3mm Aluminium Base,
- 3mm Clear Acrylic Top
- 80mm Advertising Standoffs holding them Apart
- Stainless Steel Mesh wrapped around ourside of Standoffs
- DIY Custom Cables - not enough space for anything else
- 2 x 80mm Fans to one side, beweeen standoffs
- PSU on edge, on the other side, between standoffs
- Motherboard, in between
- 3.5" Display to front
- Size 236 x 206 x 86mm
