I'm building a pc inside a Streacom F7C with the Minibox picopsu 160-xt along with a std-12160 brick (12v, 16a). As I was changing some things around with the cpu cooler, i had to disconnect the 4pin between the DIN-connector and the psu. As i reconnected them, a small spark appeared between the connectors. I had forgotten to disconnect the brick. Ever since, the PC won't boot anymore.
The picopsu still works in another pc and I tried booting the Streacom with a different psu to no avail. I can't really rule out any other parts as it's the only skylake build i have, the other one is haswell based. Am i correct in asuming that I have caused a short circuit which may have broken my motherboard? Or should I attempt some other tests?
