Hi all,
I am currently building a more amateur version of the build here: https://smallformfactor.net/forum/threads/stx160-0-the-most-powerful-atx-unit-in-the-world.934/
So far I have the internals from a Deskmini 110, with an i7 7700k and am looking to add a GPU. Looking to get a 1060 mini or higher so that it has the external power connector.
I have purchased the HDPlex 160 and am just trying to figure out the best way to power the M.2 to PCI-e riser. It currently has a FDD to 4 pin male molex cable, and I am now trying to find a female 4 pin molex to P4 but can't find any anywhere? I'm based in the UK.
On the build log quoted above and the youtube video found here:
It look likes they have a FDD to P4 cable, but again can't find them anywhere?
Can anyone direct me to where I can find these cables? Otherwise I am looking to get a female molex to sata, and would have to then use a sata cable to the HDPlex 160, which is just far more cable than I would like to have to try and fit in.
Thanks in advance,
Mark
Thanks in advance,
Mark
