Has anyone done a DemciFlex Dust Filter or equivalent dust filter for the Bottom Panel of a NCASE M3 - Grater (or other M3)? Can you share your measurements? They're not showing any "off the shelf" filters for the M3 yet.
I've gone the Custom Filter Route with them in the past, but it's a tedious process. (Measure thrice, hopefully pay to fabricate only once.)
NCASE Manual - M3 Flatpack Kit: Install Bottom Panel
Otherwise, the fact that there's no dust filter for the bottom panel bundled with the case, despite the very short, rubber "pimples" the case has for legs, I think, is a design defect. BTW, I bought the optional 15mm legs for US$10. I'm out of space for a 280mm radiator, and the case floor is the best candidate. Sucking dust into my radiator isn't an ideal situation.
Thanks in advance for any help.
