Workstation build for CAD and 3D rendering.
Dancase A4 v2 Black
i7 8700K CPU
Z370i Strix motherboard
32gb 2133mhz ram
1tb M.2 SATA drive
Nvidia Quadro P4000
Silverstone SX-650 PSU
Asetek 545-LC 92mm AIO
Noctua NF-A12x15 fan
Portable workstation for work days when I need to do lots of Solidworks CAD work and Keyshot 3D renderings, without locking up my work laptop.
Originally I had wanted to go X299 or Ryzen to build a 8+ core machine, however I had an 8700K sitting around waiting to go into my home gaming machine (6700K/GTX1080), so I decided to use what I already had instead.
Initial cooling solution was a LP53 with Noctua slim 92 2200rpm version. However the temperatures were hitting 92c while using Keyshot. It was too high for me to be comfortable with overnight render queues, so I delidded the 8700k, and switched over to the Asetek 92. It was definitely tricky to cramp all that into the front of the case. Custom length cables would have helped a ton. I also added a slim 120 to cool the motherboard. Rendering temps are now 70c.
Out of curiosity, I wanted to see how well the Quadro P4000 would game. So I fired up Overwatch, and was maxing out my 144hz monitor on 1440p high settings. Temps were at about 80c, so I adjusted the fan curve so that the GPU hovers around 70c.
Very happy with how this build turned out overall. Minor concern is the 24pin cable somewhat blocking the radiator fan. I might order some custom length cables in the future to address this.
Here are some pictures:
Dancase A4 v2 Black
i7 8700K CPU
32gb 2133mhz ram
1tb M.2 SATA drive
Nvidia Quadro P4000
