So I started my build today. It consists of a ASUS ROG STRIX x570 ITX mobo, 2 M.2 NVME drives, Noctua L9A cooler (swapped the stock 92mm fan for a Noctua 25mm high 92mm fan), 32gb ofDDR4-3200 G-Skill Trident Z memory, Corsair SF-750 power supply and an MSI GeForce 2080TI Ventus 11G GPU. The only problem I am truly having is the GPU. I have had to Dremel the front portion of the fan/shroud to make it fit and now the height (?) of the GPU is causing issues with getting the side panel on. I have attached pictures for reference. I want/need help to know if there are low profile fan shrouds available for this GPU card or (if worse comes to worse passive cooling)? Thanks for your input.
