Hi team,
Just sharing a few pics I took yesterday. Config: Dan A4 SFX v3, i7-8700, Noctua L9i (with fan duct), MSI 1060 6GT. Before snapping I let Prime95 and Furmark generate heat for 30 minutes with the case closed. The CPU long term power limit was set to 65W. The components temperature sensors indicated: CPU 79C, GPU 70C, and SSD 55C.
CPU side, side panel attached
CPU side, no side panel
GPU side, side panel attached
GPU side, no side panel
Top of the case, above the CPU
RAM
PCI-E riser
SSD
The SSD temperature sensor appears to be a good indicator of the temperature everywhere inside the case.
RAM
PCI-E riser
SSD
