Hi all,
wanted to see if anyone has attempted this, but I am looking to install a 120mm fan over the 645 LT mounted to my motherboard in my Dan A4 and most builds I've seen have just stuck it over the board. I have the 120mm aio bracket for the case and from what I've been able to see from test fitment with the components, it seems like the hole pattern on the psu quarter of the case could theoretically be drilled into the mobo quarter to let me mount the fan a bit more securely.
Now the main issue. I've never drilled holes into a metal case before and, while it seems simple on paper, I'm not super confident in my abilities. I'm wondering if any has attempted this mod, and if so, what size bit should I be looking for to drill the hole? I think the end result, if executed properly, should help out with cooling and be way more secure/professional looking.
Thanks in advance for your input.
