I bought a custom power-coated Cerberus X and just recently finished the build.
My parts list: https://pcpartpicker.com/user/altano/saved/2WZP3C
All Pictures:
Some interesting hiccups along the way:
Lastly, thanks to Sliger for custom power coating my case and thanks specifically to Carla from their sales team for making it really easy to put in this custom order.
All Pictures:
- The ASRock Taichi Ultimate motherboard has huge vrm heatsinks that limited the top fans. I could only fit either 1x120mm fan or 2x120mm slim fans.
- The Kraken X62 on the front panel limited me to 2x120mm or 1x140mm fans in the bottom
- The Kraken X62 AIO CPU cooler was totally new to me. I didn't realize a few things:
- The cooler is controlled from its "CAM" app in Windows.
- It has a customizable fan curve but the X-axis by default applies to the liquid temperature, and since the water takes a while to heat up, your CPU might get pretty toasty before the CPU cooler radiator fans spin up.
- I was eventually able to figure out how to get it to respond to the CPU temperature instead, which seems way more sensible to me and made my peak CPU temps MUCH lower (85°C to 73°C):
- When remounting the cooler for v2 (4 case fans), I didn't apply enough pressure when mounting the pump, which I think caused the thermal paste to not spread sufficiently. When screwing it in tighter my peak CPU temps dropped from 85°C to 76°C
- There is a 3-pin fan cable out of the pump that serves no purpose as far as I can tell.
- I could not mount my GPU in the x16 slot. For some reason it is just a TEENY TINY bit too far to the right to easily go in the slot. And for some reason I had the tiniest sliver more room when putting it in the x8 slot below so I gave up and left it in that slot.
