Hey guys,
I've got this motherboard in my case with a U9S cpu cooler including a second 92mm noctua fan.
Now if you've got this board, you know that they placed the chipset fans directly where the noctuas should be. I already moved the 92mms away from the rear case directly to the cpu cooler and closer to the left side of the case (yes not directly on the cpu cooler and it doesn't look the best).
Still on idle the chipset reaches a temperature of 75C and the chipset fan spins get loud which is very annoying. I can increase the speed of the noctuas to 55% and decrease the chipset temp down to 68C which makes it better but still not perfect.
For those with this motherboard, what's your fan configuration and how hot does your chipset get? Is it maybe a better option to get rid of the second 92mm fan so the PCH fan has a better airflow?
