Hello SFF community. First of all, excuse the stupid question but this is the first SFF build im doing, but cant figure out what to do. First of all - I have a Jonsbo UMX 3 case, and normally it allows 2 case coolers and a CPU cooler. Here is a rough diagram:
I got a 2700x CPU, and I am unsure about the CPU cooler. What I value the most is silence. I will not be overclocking to keep the temps down and the cooling low.
Now the question is - what do I get? Should I stick with the cooler that is coming with the box? Should I get something from Noctua (i have a closed case, dont care about aesthetics, RBG or anythings whats going on inside). Should I get an AIO cooler (and if yes, which case fan should I replace with what setup - radiator on top or on the left)? 120mm or 140mm?
Basically looking for suggestions and help. Thanks in advance!
