Hello, so i am using Ryzen 5700G with Jupiter X300, and it comes with the 19v 4.74a adapter, which is 90w. As i set the BIOS to 65w, sometimes the adapter can't handle the 5700G during gaming or heavy task as EDC will surge and causing the black screen ( and had to hard reset ) So i have been thinking a lot of ways how to stabilize my 5700G in the X300.
-What i have done so far are: set BIOS to 45W -> seems to be the most stable so far and does not spike the EDC so much.
-Sometimes meddle with PPT via Ryzen Master ( but it's unstable and random black screen happens )
-Undervolting the Cores clock speed manually via Ryzen Master ( no Curve ) -> which is ok, but i lose some core power.
-Turning off SMT
Lastly, i've think of another way on how can i use 65W without crashing the system. then i figure if it is fine to change adapter to 19V 6.32A ( 120w ) just like the Deskmini X300 version adapter, I've found a couple of aftermarket 120w Asus adapter.. would it be advisable to switch the adapter to 120W for the Jupiter? Thank you in advance
-Turning off SMT
