Power Supply Is 90% still a safe range for power used in a laptop AC adapter or is it too high?
CC Ricers
2,225
2,539
I currently have a thin mini ITX system running with a GTX 1050 working with a non-powered riser (seems like Gigabyte makes the power management run well on their boards). During gaming and benchmarks I get 80 to 85 W power used, measured at the wall. So this is after the efficiency loss converting from DC to AC.
Right now I am using a 150W AC power adapter from Dell but I want to downsize that. I found two ASUS power bricks that would look good with my setup. (the following links are just for reference, I can buy these bricks used elsewhere at lower prices)
This one at 120W: http://store.asus.com/us/item/201412AM300000015/ASUS+120W+Notebook+Power+Adapter
And this one at 90W: http://store.asus.com/us/item/201501AM080000048/A47375-ASUS-90W-Notebook-Power-Adapter
Both have a voltage compatible with my system. The 90W is about only half as big as the 120W one, but am I cutting it way too close if I go with the 90W adapter? What would be a safe minimum for my system?
Reactions: 1461748123
1461748123
489
1,068
90w should be fine. Power adapters have some headroom so realistically it should be able to handle ~95w-100w
Reactions: CC Ricers
tinyitx
2,232
2,275
You really need to dig into the two specific bricks to check on their spec. One crucial spec is whether the 120W or 90W rating is a Max Output or Continuous Output. If it is the latter, then you might be OK. If it is the former, I would avoid the 90W, at the least. As your observed 80-85W is during gaming (ie a continuous demand), 90W Max is too close for comfort. A PSU can usually deliver its max output for a relative short period of time (ie not hours of gaming).
Eg the 90W in the 2 links below refers to its max rating.
https://www.ebay.ie/itm/NEW-Origina...arger-EXA1202YH-PA-1900-30-1305-/162049466849
https://www.ebay.com/p/Genuine-ASUS...Adapter-Power-Supply-19v-4-74a-90w/2255903918
