This is just a brainfart that stimulated my curiosity. I don't own a Skyreach 4 or any SFF hardware to begin with, just wanting to share some of my brain juices here.
While browsing today something got me thinking. The Alpenföhn Black Ridge is 47mm tall. If you pair that baby with some VLP memory, you can smack a NHF12x15 underneath it and get some pretty good cooling out of it, definitely better than the NHL9i (god forgive me for this heresy).
Now, if my brain isn't complettely gone, then the following should fit snug in to the Skyreach 4 mini:
- A 9th Gen Intel CPU like the i7 9700 Delided
- A OC Frame
- VLP RAM Modules
- Black Ridge with a NHF12x15 mounted beneath
Results in a mounted cooler height of 44mm. If i have picked up the information correctly, then a delided 9th Gen Intel CPU "saves" 3mm in height and if Optimum Techs recent direct die cooling results are somewhat transferable to air coolers, wouldn't that make the best possible cooling solution, while still having a big boy GPU? Also add a undervolt to the mix.
From the one video of a Rev.2 Black Ridge mounted with VLP, there appears to be enough wiggle room to go 3mm lower. I would imagine that this would also benefit the surrounding hardware a bit with some good pressure airflow.
Another fart that escaped was when i rewatched LTT take on the S4 mini, with the cutout for the beefy RAM modules. Wouldn't a cutout for the Black Ridge make it a perfect "open air" cooler solution? Would be pretty flush (with the IHS in place ofc).
Consider my brainfart concluded.
- A OC Frame
- VLP RAM Modules
