Hi guys!
I wanted to share a project that I have been working on for some time. Last year I built this PC for a venture capital business class. We designed a mock Kickstarter campaign and I built this prototype as the product. I designed the case, but CAD work was done through UpWork (as I'm not very proficient at CAD) and the case was built by Protocase. At the time I had planned for using a modular motherboard tray and aluminum extrusions for the top and bottom, but this is actually sort of impractical for actual production. The next version of the case will be steel with magnetic dust filters and far smaller in size, probably around 5.5~6L instead of 8. I'd like for the next version to be something in between the Sentry 2.0 and the S4M.
(Side note: I'm planing on launching my company called Borderless Futures soon, but so far it's just an idea.)
Specs on the case:
Material: Extruded aluminum, aluminum panels
Finish: Black Wrinkle Powder Coat
Dimensions: 375mm x 257mm x 88mm
Supports GPUs up to 255mm (I jammed a 257mm one in there and it works)
Coolers up to about 55mm in height.
16mm Momentary Switch
Silverstone 250mm Riser Cable
Removable motherboard tray
I built it around the idea of a brickless HD Plex that could fit a well cooled RTX 2070/80 in it. I use it as an HTPC every day and the system is very stable and isn't too loud. Thermals are managable, but they'd be far better with a vented rear panel. I play most games on medium settings at 1440p, and I've taken the time to tune my fan curves. I really like the modular design of the HD Plex, but I'll likely design the next case for use with a flex ATX power supply and a mount for the HD Plex ATX with the AC-DC being external.
I'm currently going through a redesign for version two. I've learned a lot from making this case! I've been lurking on this forum for a while and you guys have been a major source of information and inspiration as well! So I wanted so say a quick thanks!
Here are the specs on my rig:
Ryzen 5 2600
Noctua L9i
Scythe RGB Fan
Trident RBG Ram, 16GB, 3200 speed
500gb Samsung Evo M.2
Msi Ventus 2070 Super
And finally pictures!!
Thanks for checking out my post!
Specs on the case:
Ryzen 5 2600
Noctua L9i
Scythe RGB Fan
