Hi SFF freaks!
I will post some pics of my NCase M1 build which I started a couple of years ago.
I made my MiniCube in the meanwhile, but that was still a long journey!
Especially finding the right pieces for my first custom loop was a hard task. The choice is sort of limited here in Switzerland, furthermore if you want to keep the price down, which is not easy in general with watercooling stuff.
And of course, fitting everything in this great ITX case was a challenge in itself, but this is where the fun is!
Well, the build is finally up and running. Still have some thing to tune up, but at least everything turned out well, which I wasn't sure of before filling the loop and pushing the power switch, so I can now present it to you!
Here are the components:
i7 6700K + Heatkiller IV copper block
Asrock Fatal1ty Z170 Gaming-ITX/ac
2x 16GB G.Skill Aegis DDR4-2400
Gainward GTX970 Phantom
Siverstone ST450F-G + Noiseblocker BlackSilentPRO PC-P 80mm x 15mm
KingFast mSATA 500GB + M.2 adapter
PNY SSD 480GB
2x 12mm Anti-vandal switch
MCubed FanAmp
Alphacool mini water tank res
Watercool WCP D5 pump + Barrow mod kit + Bitspower pump top
Watercool Heatkiller IV PRO Pure Copper + backplate
Watercool HEATKILLER GPU-X3 GTX 970 Pure Copper + backplate
Magicool G2 Slim Radiator 16 FPI - 240mm + 4x Phobya NB-eLoop 1800rpm 120mm
Magicool G2 Slim Radiator 16 FPI - 120mm + 1x CoolerMaster XtraFlo slim 120mm
Phobya temperature sensor
Barrow adapter fittings
Boom compression fittings
Tygon R6012 Norprene tubing 12,7-9,6mm (3/8"-1/2")
NCASE M1 v.2
As a start, the mobo, from red to black:
Before
After plasti dip and paint
With the RAM sticks
Check the modified heatsink next to the CPU 8pin port
PNY SSD 480GB
MCubed FanAmp
NCASE M1 v.2
Before
With the RAM sticks
