I'm considering doing a custom case in the ZS-A4M/Hahutzy 4L case, but with enough space in the front to mount a 2x92mm radiator. Basically the only options on the market are:
The 54mm M184GTX from hardwarelabs
The 45mm xt452x92 from alphacool.
A 30mm Chinese no name that seems to be out of production
Using an a9x14 and the GTX gives 68mm total clearance, while the XT45 and my 92mm gentle typhoons give a total clearance of 70mm. Anyone know which would be better?
