Hello,
Recently I've build my first sffpc in Ncase M1 and everything went smooth and without a hiccup.
I am using an old MSI GTX 660 graphics card now. I have removed the stock 2 fan shroud and use it with 2 NF A12x25s as exhaust. This is of course is far from optimal setup as the stock MSI heatsink is way too thin and there's a pretty large gap between it and the fans though the cooling is enough for my needs and the noise level is great.
Now I want to upgrade the graphics card to something budget as the new cards are eventually coming to market and I don't want to spend much money this generation but I want to spend this 6 month wait at least playing something other than d3 and DA :-)
I originally wanted to try Palit Kalmx 1650 as it seems like a perfect candidate: the dimensions are fine, stock large 2 slot heatsink. Pefomance-wise though it's not so good as 1650 supers are faster being the same price in my country. So has anyone tried to use any 1650 super model deshrouded like one would with faster graphics cards? If so which one is the best for this use case? Or is it just waste of time because low-end graphics card generate so little heat that going this route makes no difference?
