Log B-Team Lab "BB1" quick build
B-Team Lab
Just a quick build log with the BB1 ITX case.
We only made 300 pcs in Taiwan local.
Made in Taiwan, we got silver/black with EAN/UPC code.
The OEM is by Lian-Li, many thanks for their help on this project.
It's a silver one.
We design BB1 for daily use as a "desktop backup plan", so we focus on small footprint and vertical wind tunnel type.
Anodizing
It's a early 2019 prototype with titanium anodizing, in the very beginning we plan to design 3 different cabin for watercooling, due to the cost issue we simplified the design.
Just put 2 Type-A USB and TRRS here, keep it simple and useful since not many MBs with Type-C.
Contrast color in silver/black.
MB / PSU Cabin.
VGA Cabin.
Take out all the skin, we design a adjustable MB/VGA bracket inside.
Decide the CPU Cooler and VGA Card you like then decide the postion, BB1 support 3 slot VGA Card.
Install 240 AIO Watercooling first.
Put the fans on.
Quick boot test then install the PSU.
It's a old GTX1080 AERO from MSI, just build this one for my wife, she is a "fall guys" big fan...good enough for that...
a space for VGA screw.
Enough space for cables, DP or DVI, no worries about that.
The build is almost there.
We have a early sample with mini-DTX support and we made a temp test with 3 different postion, you could check here:
In the final round we decide not support the mini-DTX like C8I.
BB1 With 3080 FE and EVGA 3090 FTW are good too:
We don't have plan to go MP so far (since I have a personal business in sound testing field)
By the way we made a video with Unreal Engine:
Just a lover's project :))
