4L project [Mr.Haru] mITX+RTX2070+internal PSU+14cm thin case fan
guryhwa
G-Unique
Dec 23, 2016
164
961
project Mr.Haru is the mini version of project Mr.Nostyle by shrinking the internal psu size to 16cm*9cm*1.8cm(300w/400w available)
project MrHaru 's dimension is 303mm * 179mm*72.5mm,about 3.93L,sub 4L case club,and it is complete custom build to MrHaru's Asus Z390i mITX MB and Gigabyte RTX2070 itx VGA.
an overall picture first:
front view:
rear:
side:
internal hardware layout:
the 12V internal psu designed to be between the bottom case and vga,it is a high temp reliable type,complete fanless,its metal cover is thermal coupling to the case and also add copper sheet to help spread the heat.size is about 160mm L * 90mm W *18mm H,300watts,400watts 2 model,and typical eff is 94.5%@12V 25A output,65C case temp,220Vac in.it power the Gunique Archdaemon direct plug for MB and also the VGA:
MrHaru designed to use the style of BigWindow opening +Dust filter+filter support.the 14cm thin fan is fasten to the filter support:
to install hardware:
prepare the Vga,remove the IO shield:
MrHaru uses a completely made FPC pcie extension cable only to fit the case,which is called G-flex pcie cable:
insert the golded finger part of G-flex pcie cable to the MB's pcie slot:
then insert the pcie dummy plug to help G-flex firmly contact the pcie slots,a tape is attached to the dummy plug to help pulling out the plug when un-install it:
that is why it is called G-flex,for it is very flexible,and thin:
and install all hardware on the MB:
then put the MB and VGA into the case bottom part and fasten the screw as usual,plug the archdaemon plug,and cpu ,pcie plug too:
the rear view of VGA IO:
MB side:
forget take photo of VGA side:
front view:
so compact almost no 1mm space more at the front,the side,and the height:
plug the front usb and power switch connector and install the front bezel:
and light up:
thanks for viewing
guryhwa
G-Unique
Dec 23, 2016
164
961
reserved for Q&A
open to accept order~
BaK
855
868
As always nice work @guryhwa.
Indeed!
ArchDaemon + internal 12V PSU: am I wrong or is it the first combo that is brickless and provides 12V instead of 19V?
Very nice flexible PCIe riser!
I am surprised it works fine without any shielding!
smitty2k1
936
473
Indeed!
People have been using the Meanwell EPP or RPS AC/DC PSUs to provide power to PicoPSU (Minibox) or J-Hack plug in units. That's an all 12v solution. J-Hack also has a 400w 12v distro board similar to the Dynamo.
