Motherboard Asus z370 strix-I m.2 question?
Thauner
63
26
Denmark
Hey guys , as the title says.
I have this motherboard, and I already have a Samsung 960 installed. There is one more m.2 slot on the bottom of the motherboard, where I'm thinking of putting an extra hdd.
Can I just buy the 970 evo and put that in there, or Is there anything I need to be aware of?
Wenemun
27
31
Yep, cant see why not... Swap your 960 into it and check. As for power, like 6w average (3.3v)...
Personally, if its just for storage, id look for a cheaper 1tb sata, or get a 2tb sata for around the same price.
Thauner
63
26
Denmark
I'm in a very small case, a mod of streacom f1c evo. So I really have no space for a drive. That's why it has to be m.2 ☺
But maybe it could be a good idea to buy a cheaper m.2 drive from another brand to get more gigabytes?! It is only storage...
Seid Dark
I recommend Crucial MX500 or Samsung 860, both of them are quality SSDs that are likely to last a long time (5 year warranty). I don't think a NVME drive like 970 EVO makes sense for storage use.
Wenemun
27
31
m.2 is the connector type. nvme or SATA is the controller interface/storage protocol. m.2 can be either. nvme is like 2-3 times faster.
Reactions: Thauner
Aux
179
156
did you guys update/did you find it necessary to update the bios when using nvme?
