So I bought the ROG Strix B450-I, after reading a lot of rave for it. Paid quite a premium over my old Asrock, but I thought everything will be smooth sailing... Until I set up the fan...
So long story short, whenever I tried to setup the fan curve, on the BIOS Q-fan setting or the desktop app through Asus own Fan Xpert 4, my PC crashes. Very exasperating. Currently my setup is two linked fans, Noctua NFA14 PWM intake and Corsair LL 120 with corsair link active to display temp as exhaust. One CPU fan for Coolermaster Master liquid lite 120 and one pump. The first time I had the crash, there's a warning about incorrect fan pin header, so I checked, and everything is connected properly. If I choose the preset speed I have no issue, but when I try to fondle the manual curve, give or take 30 seconds, then my PC crashes.
Just last night I totally rave the motherboard with the Aura Sync lighting and gazillion BIOS options... Only to come up quite short on the fan setup... Which is a total deal breaker since I set my fan curve on my old motherboard (Asrock AB350 ITX) with zero issue.
Frankly this is my first Asus motherboard ever so I'm not too familiar with all of its options. Anyone has experience with Asus motherboards?
