Enclosure APU Case Roundup?
janas19
109
39
Hey guys, not too frequent poster here. Is there a roundup of APU cases available at this time? I have not been active for a while, not sure what's out there.
Thanks!
Stevo_
449
304
SoCal
Thanks!
What were you looking for in particular? Minimum size or dimensions(height/thickness versus area), brickless or bricked? Asrock A300W Deskmini seems fairly popular around here.
Reactions: janas19
janas19
109
39
@janas19 There isn't a roundup but if you tell us exactly what you need we'll help you find whatever is perfect for your use case, as @Stevo_ said.
Thank you guys. I'm mainly interested in aluminum unibody cases. A company called Streacom made some a few years ago, but they were geared towards audio/HTPC use. I'm hoping to find newer, modern cases designed for APU living room gaming . Haven't yet decided on brick or brickless. I prefer internal PSUs but I know it increases the size of the case significantly.
Reactions: Windfall
Stevo_
449
304
SoCal
Streacom is still around, they and HDPlex make a fairly complete set of fanless chassis that can be built brick or brickless depending on choices, HDPlex very chunk aluminum. On this site there's a couple of project cases that might fit the bill as well like the Mjolnir or Circle Pro, on the mass production side the SIlverstone Fortress is maybe in the category but all are large-ish to large for APU builds tho expansion options aplenty. If other materials like steel are not a problem J-Hack Pure also on this site a good brick or brickless option, as well the Lone L5 also here has options (check out my sig rig if you're in the US). Most of the builds in the build section are more gaming oriented SFF.
janas19
109
39
J-Hack Pure sounds like it would be what you want, I believe MK2 is in development right now!
Awesome, it sounds like the J-Hack Pure or Lone L5 would be right up my alley! Thank you very much!
Reactions: August
Choidebu
"Banned"
Aug 16, 2017
1,198
1,205
Perth
..., brickless or bricked? ....
We really need to decide on lingo here - brickless is fine but "bricked" is just awful. I winced everytime I saw it mentioned - reminded me of the anxiety everytime I try to flash 3rd party rom in my android devices, or bios / firmware flashing if that matter.
Choidebu
"Banned"
Aug 16, 2017
1,198
1,205
Perth
I propose few options:
  • Con mattone (like that dish, pollo al mattone) - sort of "with brick"
  • Avec brique, or.. Au brique. Kinda sounds like oblique..
Or for a bit of fun:
  • Vis a brick (a play on 'vis a vis' - let's just say it means "your-face-to-a-brick")
  • Brickeroo (just sounds right.. ya wanna run ya rig brickeroo oight mate)
Disclaimer: I am neither french nor italian, and I do not speak these languages so I just pull that outta my arse.
Choidebu
"Banned"
Aug 16, 2017
1,198
1,205
Perth
Or maybe we can swap the pc to brick relationship 180°...
For example say that the pc is "tethered" to a brick...
Or "dongled"... stupid i know.
Reactions: August
Stevo_
449
304
SoCal
OK, following along with that line of thought how about this; brickless comes on the inside, brick comes on the outside. That should be clear where you want to be ;).
