Hi Everyone!
I'm excited to show you a project I've been working on for the last little while. I call it the AOS Crossbow. It's an open air sandwich case/frame with support for up to SFX-L power supplies and GPUs up to 315mm (TBC may go bigger based on your feedback).
This case is for people who want the exceptional thermals and low noise afforded by an open air design while also turning their PC into a mini art installation for their components!
All the cables and drives fit within the central spine of the frame out of sight for a clean look, while all the connections for GPU, Motherboard IO and Power come discretely out of the bottom of the case where they can be cleanly managed to where they need to go. You'll use a right angled C13 power cable that is internally routed through the spine of the case to connect to the PSU.
GPU is connected via a riser cable that passes through the spine.
Cutouts in the spine support flow through GPU coolers (although for thermals a standard axial design will probably perform best).
Assembly is a breeze as far as SFF PCs go as you can assemble the two halves of the case separately and then connect them together with all the cables inside as the final step!
What I need help with:
1. Feedback on the design
2. Suggestions for manfuacturing partners (I've contacted Lian-Li and Protocase already)
Background on me in case you're interested:
I'm an aerothermal engineer by training and over the last year I've been designing FPV drone frames and selling them around the world with the help of several manfuacturing partners (you can find me on YouTube https://www.youtube.com/c/chrisrosser). I've always been passionate about SFF PC cases so this project is an exciting one for me!
