Hey guys,
As part of the Open Benchtable Project, I am looking for your feedback as SFF enthusiast. After the success of the first iteration of the project ( The BC1 : a full size ATX open-air case / benchtable), we were looking into some other way to extend the project.
Some people asked us for a Mini-ITX version, here is a mockup of what it could be...
(The big one is the actual Open Benchtable while the small is the Mini-ITX idea)
Details :
- Mini-ITX support
- SFX PSU support (no ATX)
- Support 2.5' drive
- Thumb Screws for fixing anything you need
- Push-pin
- PCI-E brackets
- Extension bracket for AiO or fans
Note : This is a mock-up, the feedback will help out on shaping it.
Your feedback matters !
- What would you love to see added ?
- Would you consider buying this type of mini-ITX open-air case ?
- Any constructive feedback is good feedback
Suggestions : (updated)
- Wall Mount (kinda available as the 2 PCI-express brackets use 2 holes in the feets)
Disclaimer : I am part of the OBT Project
For all the details you can check on the original version you can check the OpenBenchtable Site
Note for Mods : This is a Feedback Thread
Update October 19 :
The OBT-Mini is now available : https://openbenchtable.com/news/introducing-bc1-mini-small-form-factor/
The SFF community had some interesting feedback that hopefully made it in the final version.
I am now looking forward to feedback with end-user usage
Details :
- Mini-ITX support
- Push-pin
- PCI-E brackets
Update October 19 :
