Here is a TL/DW summary of the event.
AMD has released more details on their upcoming ZEN CPU's. The processors with the Zen architecture will now fall under the brand of Ryzen. Although AMD did not dive into specifics about their upcoming CPU's, they did reveal some technologies that helped they achieve and surpass their performance goals.
The Ryzen CPU's have 5 new technologies that helps boost their performance and efficiency goals. These are branded as SenseMI and use machine learning to optimize the CPU workload.
AMD did show off the performance of a ZEN CPU with the following specs:
- 8 Core/16 Threads
- Base clock of 3.4Ghz.
- 20MB of L3 Cache
- 95W TD
Benchmarks: In the
VERY brief Benchmarks, they compared the aforementioned CPU with Intel 6900K, an 8C/16T chip. With both chips are stock, both CPU'S were neck in neck with the AMD CPU coming out on top in a couple of Benchmarks.
Most notably, the Zen CPU beat the Intel in a game stream environment and in handbrake. Since we don't know the settings at which the Benchmarks were run at, take the results with a grain of salt. Furthermore, we did not get exact data for some of the benchmarks. We will have to wait for review samples to get the information we want.
At the end of the event we did get to see a new Vega GPU in action. It ran the upcoming Battlefront Rogue One DLC at 4k. Again, the only information we got was "It's running at higher then 60FPS." We don't have any data you compare against. So yeah...
¯\_(ツ)_/ ¯
