Thought this might strike the fancy of some people here - I've definitely been dreaming up some "what if there were ultra slim rads" ideas throughout the years. Remember seeing these at some trade show, but now they're actually available
Rads are full copper, cross flow (ports on both sides) and for either 40mm or 80mm fans (though with the static pressure needed for these its likely better to use a radial fan unless you want a server-grade hair dryer or are using low-powered parts. 40mm ones run from 1 to 7 fans, 80mm 1 to 4.
https://www.techpowerup.com/254082/alphacool-unveils-nexxxos-40mm-and-80mm-server-radiators
Now, who'll be the first to stick one of these into an S4 mini and cool both the CPU and GPU with it?
