SFF.Network Akasa Venom RG prototype ITX case, SFX/SFX-L PSUs, and more
3lfk1ng
919
1,718
www.reihengaming.com
Y'know... I actually like it.
It is a little on the pudgy side but overall it's different and looks like it allows for plenty of ventilation.
4,788
I quite like it too, it's not the smallest but it look neat.
Hopefully the internal layout isn't trash.
no_one
Jan 25, 2016
49
Right as I finished putting together a new HTPC in the VT01, someone puts out a fanless STX chassis! Well, I guess I have an excuse to buy more hardware now :p
Any chance you took a higher resolution photo of that spec card? I'm curious about drive support & whatnot (assuming the design is finalized).
4,788
I don't have a good pic of the spec card, but all I can make out is that it supports 2x 2.5" drives, has a serial port, VESA mounts, and I think a Kensington lock?
