Hey guys and gals, im seeking advice to the best way to undervolt the 5600 CPU i have, i know there is ways to change the PPT/TDC/EDC limits and i've always been scared away from attempted to use ryzen master as CB use to crash when the system reached 85degrees (on my 5800x build). I suspect i would get the same from the 4L build, but would like some advice to reduce some specs on both the CPU/MB combo and the GPU without scacrficing too much in the way of performance.
Im a bit of a noob when it comes to over/under clocking and the closest i have got is by setting a neg PBO curve and disabling the CPU limits, so dont quite understand the inner workings.
