Hello, I'm completely new to SFF and am soliciting advice of how external power works. I'm currently planning on a 3600 + 1660 super/ti build in a MC600 case, which is not going to fit a SFX/flex PSU. The wattage calculator on newegg suggests that I should be looking at around 240W of power draw, which makes sense since the 3600 draws 90 at peak from Anandtech graphs and the 1660ti draws 130, and adding a few watts here and there for fans/ssd/etc.
So my primary question here is what are my choices for external power. My understanding is that there's a DC-DC that sits on top of the 24pin on the motherboard and a AC-DC external power brick that feeds power into the DC-DC. But I'm having trouble finding what people use for both of those components; the only easily accessible one I've been able to find so far is:
- The picoPSU 192W combination unit, which is clearly insufficient (or is it? Can I power limit the cpu/gpu to not draw more that 192W total?)
- A custom order one that people order through another thread that I lost the link to and can't find again
- The 400W thing from HDPlex which seems to only cover DC-DC with the AC-DC portion (https://hdplex.com/hdplex-internal-400w-ac-dc-adapter-with-active-pfc-and-19vdc-output.html) also expected to be internal.
To summarise:
- What are my options for a 250+W external power brick/combination/whatever they're called? Where do people find these in general/what keywords should I be putting into google?
- Can I / is it a good idea to limit system power draw to 192W so I can cram the 192W picoPSU into the build?
- Is there an easy way of cramming a flex PSU somewhere and sidestepping the whole problem? I don't really care about the case as long as volume stays less than roughly 5-6L, so is there a simple case somewhere that I missed that would make the problem go away (and won't break the bank)?
To summarise:
