Greetings,
I'm looking for a little advice or perhaps reference info for upgrading my current build in my Ghost S1 case.
Currently I have :
Asus Z370-I Mb
Intel I7 8086K special ed CPU
16gb G skill DDR4 3600 RAM
Noctua NH-L12 Ghost Edition CPU Cooler
Corsair SF850 power supply and a just added
MSI 4070 Ti Super GPU
All installed in the kickstarter version of the Ghost S1 which I am very disinclined to give up.
My issues started with the GPU upgrade (from a 1080 gtx) to the current 4070 Ti Super. While installing everything I came to discover that one of the ram slots on the Z370-I MB is bad so instead of 32gb I am stuck with 16 for the moment. Performance of the new GPU card is less than impressive and not much better than the old 1080 in some titles . However, since some titles are remarkably better I going on the assumtion the CPU/MB is the bottleneck. It is clearly time to upgrade the CPU and MB, but I'm not sure what combination (particularly the CPU) A) have a descent mini ITX form factor and b) will remain generally cool enough for the NH-L12 cooler to do its job as effectively as it currently is. I am agnostic regarding Intel vs AMD having owned and built systems with both in the past, so suggestions for either would be appreciated. This will be a system that will be used for gaming , but I won't be overclocking anything so that won't be a factor for MB/CPU choice. If anyone has experiences or advice to share I would really appreciate it, Thanks
Currently I have :
Asus Z370-I Mb
