[Advice] $2k Gaming SFF based on Dan Cases A4-SFX 4.1
FraBle90
Hey everyone,
I'm currently doing my research on building a ~$2k Gaming SFF based on the Dan Cases A4-SFX 4.1.
Here is my list so far:
CategoryManufacturerProductPrice
CPUAMDRyzen 7 3700X$274.99
MotherboardGigabyteGigabyte X570 I Aorus Pro WIFI$219.00
MemoryCorsairVengeance LPX 32 GB DDR4-3200$138.99
Storage (M.2 SSD)Seagate1TB FireCuda 520 M.2 Internal SSD$249.99
GPUGigabyteGeForce RTX 2070 SUPER WINDFORCE OC 3X$499.99
Power SupplyCorsairSF600 Platinum$159.95
CaseDan CasesA4-SFX 4.1$219.00
CPU Cooler Asetek645LT 92MM AIO$95.00
Thermal CompoundThermal GrizzlKryonaut 1g 1 g Thermal Paste$9.25
Extra Case FanNoctuaNF-A9x14 HS-PWM chromax.black.swap 92 mm$19.90
Custom PSU Cablespslate customsDAN Cases A4-SFX 24 Pin Unsleeved Custom CableN/A
Custom PSU Cablespslate customsDAN Cases A4-SFX 8 (4+4) Pin CPU/EPS Unsleeved Custom CableN/A
Custom PSU Cablespslate customsDAN Cases A4-SFX 8 (6+2) Pin PCIE Unsleeved Custom CableN/A
Custom PSU Cablespslate customsDAN Cases A4-SFX 6 Pin PCIE Unsleeved Custom CableN/A
Mod Kitu/LosercardDan A4 Ultimate Cooling Bracket and Fan Set$53.00
~ $2,000
I'm looking for advice from the community ?
  • Does this list make sense?
  • Do I miss anything / any components?
  • Are these components compatible (e.g. dimensions)?
  • Can I optimize anything (e.g. CPU vs GPU balance)?
Cheers,
FraBle90
greentypewriter
The only thing I'll say or rather ask is if you'll be upgrading to the 3000 series RTX when they drop -- I'm reading that their entry level $500 cards are going to match or exceed 2080 supers -- meaning you may find it hard getting a competitive price when reselling that GPU.
kmnvhs
21
instagram.com
1. I think 32GB Ram is useless for gaming -> 16GB is perfect for the next years.
2. why do you want to water-cool the 3700x? in my opinion the a4 with 92mm are not look that good and the cable routing is hard
-> maybe switch to the alpenföhn blackridge with a Noctua nf-a9x14hs (chromax) -> that's more than enough for the 3700x. I used that combo with a lil undervolt (1.2v) and the results are amazing -> 4.25GHz Boost (standard) and 65C max temp. But the Blackridge need LP Ram like the corsair lpx (maybe 3200/CL16)
== the saved cash can be invested in a better gpu -> but the 2070 Super is the best price to performance gpu.
thelaughingman
1,413
1,566
@kmnvhs BR will not work out of the box with X570i Aorus, either you need to remove the PCH fan/heasink combo or have to shift the fan towards the heatpipes to clear. 32GB RAM is good for future proof, Chrome just eats RAM for days.
@FraBle90 maybe get 3600Mhz RAM instead for some extra performance. If you strictly game, maybe switch to a 3600 (100USD cheaper) or 3600XT (4.5Ghz boost clock) + a B550i board for a more optimized config. And echoing above comment about the GPU, I would not feel comfortable dropping 500USD on a card when it's so close to the launch of the new generation. Maybe get something in the 250-300 range as temp/placeholder and then upgrade. Hope it helps.
kmnvhs
21
instagram.com
1. it works out of the box (blackridge + Aorus x570i) - plug and play without any problems (do it in a A4, Louqe S1).
2. nobody uses chrome if you prefer privacy stuff -> use firefox for better privacy
  • Haha
Reactions: thelaughingman
