Hello SFF Commmunity.
I always wanted to have a Distro Plate like EK´s Quantum FLT 120 but smaller, since the 120mm version wont fit at the back of an Ncase M1, NR200, etc.
So I designed one, I actually have three different 3D models for this, but the last one I put in the most work and time.
The overall dimensions are 92mm X 92mm X 20mm without the DDC Pump and/or Fittings. The front plate is 15mm thick, the one on the back is 5mm.
For this design the two Plates are kept together with M3x20 and M3x10 screws. the DDC Pump is mounted via four M4x25 screws and the Plate can be mouted on the Case with M3 screws, length depends on the thickness of the Case. The Distroplate has two Output Ports and three Inputs. The top Input is purposed to be the Fill port..
Here are some Pictures
Front View:
Back View:
Back View orthagonal:
Back View orthagonal only Plate and O-Ring:
I´m currently making a Prototype to Check that everything is working as intended.
What do you guys think? Do you have any suggestions to improvements for my design.
Is there anyone who would also have such a distroplate?
Front View:
![](https://i.imgur.com/slVHjYR.png)
Back View:
![](https://i.imgur.com/ZXa2p1J.png)
![](https://i.imgur.com/4FuAJr9.png)
![](https://i.imgur.com/5Z6Moh1.png)
