Hi all, built the little 4.3L machine and it runs hot just like its older brother the 5800x.
Build is a A39 Case, R5 5600 CPU, Asrock b550 MB, Kingston Rage 3200 DDR4, 1650 Super, Noctua NH-l9a cooler and a Enhance 600w PSU. Not much more i can put in this one, its quite packed.
I ran the multi core stress test and it reached temps of 88deg, which i suspect is from the sides, small CPU fan and maybe a gap between the cooler, so might try some of that foam tape used for drafts as i have some of that and if it works its a cheap mod. Also did a negative PBO curve of 20, which i thought would do something, but not sure it did.
tried this yesterday and think with the sides off it runs cooler, but need to check it.
One last thing, with windows it wants to sign in continually, even when going to netplwiz (which doesnt have ability to remove sign in tick box maybe as i havent registered windows yet).
