I have been looking around the net for as much info as possible especially anyone who has the NCASE M1.
I have the opportunity of picking a FE up from a friend tomorrow, i currently have the EVGA XC3 on pre-order which i will cancel should i get the FE.
Now the only thing holding me back is will it fit, seems very mixed reviews ? also bothered about fitting the side panels back on , my plan would be to install the EK block eventually.
Can anyone shed any light on info or had the opertunity to test ?
Many thanks
Many thanks
