Hello!
I've just gotten a Dan A4-sfx v2 for about $100 which was way to good of an offer to refuse!
I've filled it with:
Msi Z370i Gaming Pro Carbon
i5 8400
2 x Corsair LPX 3000Mhz @ 3200Mhz
Gigabyte 1080ti OC
Corsair SF600
512gb m.2 Nvme on the back of the Mobo
1920gb ssd from Kingston.
To cool all of this I'm using:
Noctua NH-L9i - reason for this was when I was about to pick up a C7 I read that it can create turbulence and too much noise
2 x NF-A9x14, one under mobo (tight fit, really tight, didn't even have to use screws. Did have to convince the riser to move a tad more north though ) and one under the Power supply.
Replaced the fan on the GPU with 2 x Noctua NF-A12x15.
Temps are about 65-70 C on both CPU and GPU, before the addition of the fans (and replacement of gpu-fans) the CPU was at 75-80 and GPU about 75 when playing Cod:MW (2019)., 5-10 degrees difference, not to shabby!
Now, I've searched and searched about if anyone else did the same with 2 x 120mm-fans, but didn't find anything.. Anyone done it?
Would it be better to use those fans as exhaust?
See these two images:
i5 8400
Gigabyte 1080ti OC
Corsair SF600
