2600 temps
JohnQi
Hello,
I just wanted to double check if the temps I am getting with my are ok.
While gaming I am hitting ~78C and idling at ~45C.
I was expecting ~65C for gaming, specially with the 2 extra fans, so I don't know if I did something wrong is just my paranoia.
Thanks in advance =D
CPU: AMD - Ryzen 5 2600 3.4 GHz 6-Core Processor (€168.90 @ Amazon Espana)
CPU Cooler: Noctua - NH-L9a-AM4 33.84 CFM CPU Cooler (€41.10 @ Amazon Espana)
Motherboard: ASRock - B450 GAMING-ITX/AC Mini ITX AM4 Motherboard (€140.72 @ Amazon Espana)
Memory: Corsair - Vengeance LPX 16 GB (2 x 8 GB) DDR4-3000 Memory (€135.00 @ Amazon Espana)
Storage: Samsung - 850 EVO-Series 1 TB 2.5" Solid State Drive (Purchased For €0.00)
Video Card: MSI - GeForce RTX 2060 6 GB VENTUS OC Video Card (€374.90 @ Amazon Espana)
Case: DAN Cases - A4-SFX V3-S Mini ITX Desktop Case (€210.00)
Power Supply: Corsair - SF 600 W 80+ Platinum Certified Fully-Modular SFX Power Supply (€125.90 @ Corsair)
Case Fan: Noctua - NF-A9x14 29.72 CFM 92mm Fan (€17.78 @ Amazon Espana)
Case Fan: Noctua - NF-A9 PWM 46.44 CFM 92mm Fan (€17.90 @ Amazon Espana)
Other: HP 22w - Monitor de 21.5" (FHD, 1920 x 1080 pixeles, tiempo de respuesta de 5 ms, 1 x HDMI, 1 x VGA, 16:9) color negro (€109.00 @ Amazon Espana)
Total: €1341.20
dondan
DAN Cases
1,871
7,946
What is the CPU fan speed at 79°C?
How do you monitor temps?
Did you tried undervolting? (Offset -0.07V)
How much thermal paste did you attach?
What are your temps with side panel off?
Reactions: JohnQi
JohnQi
Hey, dondan!
I turns out my cpu cooler was not well seated. I removed everything, reapplied thermal paste and tie the screws properly and now it looks like the thermals are a bit better.
I am getting average 72C with a max 73 while gaming, without hitting the max fan speeds.
But to answer you questions:
1. The cpu fan speed curves were set to max everything if temps went over 75C.
2. I was using a combination of Core Temp and CPUID HWMonitor to check the temps (Core Temps keeps the temp logs every 10s).
3. I did not try to undervolt the cpu.
4. I tried the usual pea size method, but it is no use if the cooler is not touching the cpu at all points =p.
5. I did not check the temps without the side panel.
JohnQi
Ok great. With 72°C the temps are good. If you like to lower them (5-7°C) set offset Voltage to -0.05 or - 0,075V. Also a fan duct (3D Printable files https://www.thingiverse.com/thing:3003566) Will reduce the temps another 5°C. So i think 62°C is possible :)
I installed the fan duct and could not be happier.
It dropped my average while gaming from 70°C to 64°C.
You should consider make it as an additional feature for the case =D
Reactions: chiliwili
