So since my recent post in re: the kraken g12/645lt on my 1080 ti, which did little other than turn the poor little aio into a chimenea, I've reattached the heatsink and fan shroud and installed an nf a9x14 hs and a scythe kaze jyu slim (rip other uses for these fans). temps and noise are great, but they're on there with little more than some two-sided tape. Given the temps put off by this little card, I'm assuming that normal two-sided tape is a relatively short term application strategy. Wonder if anyone has any suggestions for a better adhesive (stock screw points won't work with the base of the fan motors). I was thinking thermal tape or something like that, but suggestions for something not so janky would be greatly appreciated.
Also, if anyone is aware of a short 4 pin to dual PWM splitter (the one I have is way too long and creates a lot of excess wires with the stock fan wires from the two case fans.
Thank you in advance
