NFC stands for Not From Concentrate. I want my customers to have the full ability to customize their S4 MINI's as they see fit. These are the .dxf files I use to laser cut the 2D bezels you can buy on my website.
If you want to do something custom, or you have your own laser and can do them cheaper, these files should work for you. For your own personal use only, please.
- Product Page
- http://nfc-systems.com/shop/2d-bezel-7mm
