Noctua NH-L9i
.SKP & .STEP Noctua NH-L9i v1.0
Detailed STEP model of the Noctua L9i heatsink.
The NH-L9i is a premium quality quiet CPU cooler for Intel LGA115x based HTPCs and Small Form Factor systems. At a super-low profile of only 37mm, the NH-L9i is ideal for extremely slim cases and due to its 95x95mm footprint, it provides full compatibility with tall RAM modules and VGA cards on mini-ITX mainboards. The custom designed SecuFirm2™ mounting system for LGA115x makes installation a child’s play and thanks to the highly optimised NF-A9x14 premium fan that supports fully automatic speed control via PWM, the NH-L9i runs remarkably quiet. Topped off with Noctua’s renowned NT-H1 thermal compound, the NH-L9i fuses everything users have come to expect from Noctua’s larger coolers into a super-compact package for slim HTPC systems.
Measured with calipers and the model is accurate to within 0.5mm.
Also included are STEP and SketchUp files of a simplified version for part fitment checking:
This model does not include the fan, so be sure to check out @QinX's fantastic model of the NF-A9x14!
Reactions: BaK
Author
Downloads
222
Views
2,777
First release
Last update
Rating
0.00 star(s) 0 ratings
More resources from jeshikat
