Noctua NH-L12
.SKP & .STEP Noctua NH-L12 v1.0
The NH-L12 is a low-profile quiet cooler designed for use in small form factor cases and HTPC environments. With its flexible NF-F12 (120mm) / NF-B9 (92mm) dual PWM fan setup, the NH-L12 can be configured either for full performance in dual fan mode or extra-low profile (66mm) with the top fan removed. Bundled with the award-winning NT-H1 thermal compound and Noctua’s SecuFirm2™ multi-socket mounting system, the NH-L12 packs everything a premium quality quiet cooler needs into a highly compact package.
Most of the model is accurate to within 0.1mm, with special attention paid to the block and mounting ears.
Note: The heatpipes are much less accurate though, so be sure to leave clearance room around them in the model to be safe.
The fan and motherboard mounting brackets are not included. The LGA 2011 brackets will be uploaded in the next several days. And I'd recommend my NF-P12 model if you need a fan.
Reactions: CircleTect
Author
Downloads
134
Views
1,879
First release
Last update
Rating
0.00 star(s) 0 ratings
More resources from jeshikat
