HDPlex 400w
.SKP HDPlex 400w 2018-11-29
Quick HD plex 400w AC-DC made from plans given on the webpage. Its just a shell.
HDPLEX 400W.AC-DC is an internal high efficiency AC-DC adapter. It is designed to work with HDPLEX 400W/800W DC-ATX and Thin-ITX/NUC platform. It accepts 90-264VAC input and outputs 19VDC. The working efficiency is up to 94% and the extremely low no load power consumption is down below 0.5W. Its compact size (180x58x40mm) and versatile mounting options enable powerfull performance in small package. HDPLEX 400W AC-DC works with NFC S4M case out-of-the-box.
Author
Wenemun
Downloads
57
Views
2,210
First release
Last update
Rating
0.00 star(s) 0 ratings
