The now ubiquitous EVGA GTX 1060 (There are half a dozen different models. Same shroud, board size etc...)
This is an extensive remake of another file i found on 3d warehouse, but with internals and (nearly) correct shroud. This is so you can tear it down, and put your own watercooling block, shroud etc, or in my case, a 120mm rgb on top.
Here's an exploded view.
