Hi!
I have a ZS-A4 V3, case is very good but the C6-C13 power cable looks so ugly with those three single wires glued on the C6 connector.
So I'm thinking about change it, and I came to two ideas:
Have a nice day
- Mod the back of the case to fit the standard C14 socket as all the other cases around
- no idea about how to do it, don't even know if it's possible. I would like to have your help
- Mod the cable
- I was thinking to buy a standard C13-C14 power cable, cut off the C14 connector and solder the wires on the C6. Is this possible/compatible? Also every C6 that I've found on internet is rated for 2.5A while the original one is 5A. Is it possible to remove the glue from the original one so I can use it for my idea?
Have a nice day
